About if statement
Hello. I am working on a script which give out different results from different combination of bool input.
I am just familiar with dynamo package while barely know about coding.
As the picture shown, there are two input (True/False) and four kinds of output. The difficulty I met is I do not know how to present it correctly. Thanks if you could help me.
@TCKEAHY just remove the DSCore.if
@TCKEAHY : not ;
@Elie.Trad Thanks a lot. My bad.
To clarify a little bit, DesignScript uses a shorthand version of the If conditional statement, not a direct translation of the node. It actually matches a typical conditional statement (which returns true or false directly) except that an If statement returns something depending on if the condition is true or false.
The shorthand looks like this:
condition ? trueResult : falseResult;
where condition is the conditional If statement, trueResult is the output when the condition is true, and falseResult is the output when the condition is false.
@Nick_Boyts
Thank you for the supplement.
