A mistake with Entity and Schema while changing duct fitting coefficient
Sorry, I can’t attach a file because I’ve just registerede yesterday. But I can attach a code. This code I take from that: Change Duct Loss Coefficient to Another Fitting in ASHRAE Table - #21 by til.shviger and changed it for specific coefficient
clr.AddReference(“RevitAPI”)
from Autodesk.Revit.DB.ExternalService import *
from Autodesk.Revit.DB.ExtensibleStorage import *
clr.AddReference(‘ProtoGeometry’)
clr.AddReference(“RevitNodes”)
clr.AddReference(“RevitServices”)
def getServerById(serverGUID, serviceId):
service = ExternalServiceRegistry.GetService(serviceId)
if service != “null” and serverGUID != “null”:
server = service.GetServer(serverGUID)
if server != “null”:
return server
return null
lc=
def getLossMethods(serviceId):
serverIds = service.GetRegisteredServerIds()
list=ListElementId
for serverId in serverIds:
server = getServerById(serverId, serviceId)
#ductServer = server.IDuctFittingAndAccessoryPressureDropServer
	id=serverId
	name=server.GetName()
	lc.append(id)
	lc.append(name)
	lc.append(server)
return lc
elems_=UnwrapElement(IN[0])
SetNew = IN[1]
elem=
elems=zip(elems_, SetNew)
for el in elems:
eleId = el[0].Id
fitting = doc.GetElement(eleId)
param = fitting.get_Parameter(BuiltInParameter.RBS_DUCT_FITTING_LOSS_METHOD_SERVER_PARAM)
lc = getLossMethods(ExternalServices.BuiltInExternalServices.DuctFittingAndAccessoryPressureDropService)
schema = lc[8].GetDataSchema()
field = schema.GetField(“Coefficient”)
entity=fitting.GetEntity(schema)
oldval = entity.Get[field.ValueType](field) # obtaining values
entity.Set[field.ValueType](field, el[1]) # installation of a new coefficient value of certain
fitting.SetEntity(entity)
elem.append(fitting)
OUT = elem ,lc
#OUT = [UnwrapElement(i).FieldName for i in schema.ListField
