Super naïve qs did lacing/levels change between 22/24 or am i missing something obvious.
Cheers K
Shouldn’t have, but something fishy is going on here. Can you try it with a code block providing the proceeding numbers into the x-y node to see if that reproduces? If so delete all the other nodes and post the graph so we can flag for a developer to review. Thanks!
Something is likely off with the data types. Try an object type node for both data types.
Hi @jacob.small
Is this what you mean?
Original Data list is systemDoubles but outcome is different between 22 & 24
Cheers KS
Please post the graph and a sample model to reproduce with for review, along with the versions you are using (i.e. 2024.1.3 or 2024.0.0).
