2 lists of booleans in "and" function
So I was wondering how you can make the “And” node working with two different lists full of booleans.
For example:
list1:
list2:
Result
1: true
2: false
3: false
4: false
5: false
6: false
7: false
8: true
9: false
10: false
etc
Thanks in advance!
Edit:
@remco.dejong ,
what do you want? join the list?
or count all true and false together?
Use the &&
I wanted it to check if both values were true, and if it were so then make it display a true value
if only one of the two, or none is a “true” then it should display false, just like Alien commented below.
Great thanks, exactly what I needed. Of some nodes you just dont know the existence.
