Zoom to a specific location in model space
I am not sure but there might be a node to set a view to a viewport. And nodes to create a named view in modelspace. At the moment I can’t check how it works, maybe tomorrow.
There is no node yet to set a view to a viewport. I’ll put it on the wish-list.
Does anyone know why I have this message error:
Warning: NameError : name ‘acapp’ is not defined [’ File “”, line 29, in \n’]
This is the code I modified:
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
import System
from System import Array
from System import Collections
adoc = acapp.DocumentManager.MdiActiveDocument
ed = adoc.Editor
civdoc = CivilApplication.ActiveDocument
AcadApplication = Autodesk.AutoCAD.ApplicationServices.Application
name = IN[0]
layer = IN[1]
def explode_stpoints(name, layer):
    error_report = None
    res = []
    object_ids_list = []
    try:
        with adoc.LockDocument():
            with adoc.Database as db:
                    # Place your code below
                    bt = t.GetObject(db.BlockTableId, OpenMode.ForWrite)
                    btr = t.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite)
                    lm = LayoutManager.Current.CurrentLayout = name
                    lmm = LayoutManager.Current
                    objly = t.GetObject(lmm.GetLayoutId(lmm.CurrentLayout), OpenMode.ForWrite)
                    vids = objly.GetViewports()
                    if vids.Count > 0:
                        vport = t.GetObject(vids[1], OpenMode.ForWrite)
                        vport.Locked = False
                        vport.On = True
                        vport.Visible = True
                        ed.SwitchToModelSpace()
                        command = f"QSELECT\nL\n==\n{layer}\nEXPLODE\n"
                        adoc.SendStringToExecute(command, True, False, False)
                        ed.SwitchToPaperSpace()
                        vport.Locked = True
                        vport.UpdateDisplay()
                        commandq = "_QSAVE\n"
                        adoc.SendStringToExecute(commandq, True, False, False)
                    t.Commit()
    except:
        import traceback
        error_report = traceback.format_exc()
    if error_report is None:
        return commandq
        return error_report
OUT = explode_stpoints(name, layer)
adding this to your code
Thanks, but still doesn’t work:
start By writing the code Line by line
from here
# Add Assemblies for AutoCAD and Civil 3D APIs
clr.AddReference('acmgd')
clr.AddReference('acdbmgd')
clr.AddReference('accoremgd')
clr.AddReference('AeccPressurePipesMgd')
clr.AddReference('acdbmgdbrep')
clr.AddReference('System.Windows.Forms')
clr.AddReference('Civil3DNodes')
# Create an alias to the Autodesk.AutoCAD.ApplicationServices.Application class
#import Autodesk.AutoCAD.ApplicationServices.Application as acapp
acapp = Autodesk.AutoCAD.ApplicationServices.Application
# Import references for Civil 3D
import System
ed = adoc.Editor
name = IN[0]
layer = IN[1]
    error_report = None
    res = []
    try:
                    #bt = t.GetObject(db.BlockTableId, OpenMode.ForWrite)
                    #btr = t.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite)
                    #lm = LayoutManager.Current.CurrentLayout = name
                    #lmm = LayoutManager.Current
                    #objly = t.GetObject(lmm.GetLayoutId(lmm.CurrentLayout), OpenMode.ForWrite)
                    #vids = objly.GetViewports()
                    t.Commit()
    except:
        import traceback
        return name
        return error_report
Thanks @hosneyalaa,
That worked, now the problem is only in my code.
I was close, I will continue trying and investigating if my code is correct, if I can’t, could you help me. :sweat_smile:
wirte code by ironpython2 will working
1
@hosneyalaa I tried,
but looks like there is an error in my code,
There is my code by the way I hope someone can help me.
import System
ed = adoc.Editor
name = IN[0]
layer = IN[1]
    error_report = None
    res = []
    try:
                    if vids.Count > 0:
                        vport.On = True
                        vport.Locked = True
                    t.Commit()
    except:
        import traceback
        return name
        return error_report
TRY
import System
ed = adoc.Editor
#import AcadApplication
#XX= IN[1]
#YY= IN[2]
vp  = IN[1]
name  = IN[0]
def move_labels( name,vp ):
	#if not hasattr(objects, "__iter__"):
		#objects = [objects]
	#if not hasattr(yy, "__iter__"):
		#yy = [yy]
	#if not hasattr(lys, "__iter__"):
		#lys = [lys]
	error_report = None
	res = []
	try:
		            #ii = 0
		            lm = LayoutManager.Current.CurrentLayout =name
		            if vids.Count > 0:
		               command = "zoom\nA\n"
		            t.Commit()
	except:
		import traceback
		return vport
		return error_report
OUT = move_labels(  name,vp  )
11
Method to use API to center Model Space to UCS coordinates
import traceback
clr.AddReference("AcMgd")
clr.AddReference("AcCoreMgd")
clr.AddReference("AcDbMgd")
ed = adoc.Editor
            try:
                if not db.TileMode:
                    db.TileMode = True  # Model space
                # Define in UCS coordinates / units
                centerpoint = IN[0]  # list of [x , y] coordinates
                width = IN[1]  # int or float
                current_view = ed.GetCurrentView()
                # Just move view - no scale
                if not width:
                    width = current_view.Width
                ratio = current_view.Height / current_view.Width
                current_view.Width = width
                current_view.Height = width * ratio
                current_view.CenterPoint = Point2d(0, 0)
                current_view.Target = Point3d(*centerpoint, 0)
                ed.SetCurrentView(current_view)
                OUT = current_view.Width, current_view.Height, current_view.Target
            except:
                OUT = traceback.format_exc()
            t.Commit()
Cool, Thanks.
Now I get a message that my Iron Python 2 package is not installed but when I go to install it I get a message that the package is already installed.
What should I do?
I solved it, uninstalling it and installing it again.
Now let me try my code.
Thanks @hosneyalaa
I add this line
 command = "-qselect\nL\nC_POINTS_Setout Point\nEXPLODE\n\n"
but I don’t know why is asking me to drawn a line, where I can find a guide to learn how to use this method.
Where did you get it from?
It won’t work for you Because he A window appears
11
It is suppose that -qselect open qselect as a hide mode, I got it from chatGPT :sweat_smile:
I expected this
So I asked you
I’m still looking for learn how to do that what do you suggest me?
I do not know ,What do you do
without Example drawing
Want to explode points?
do before moving in layout
The problem with explode the points in the model is that when you return to the layout the orientation of the labels moves, this does not happen when you enter the viewport and explode them from there.
