Hello ,
Using zero touch node can i create a drop down node to select element from list ?
If it s possible any help or insight will be appreciated and mush thankful .
Best Regards,
You can find some example code here:
“Next week” was a bit optimistic but finally I was able to do some testing. And I got result.
There are two things you should know:
It seems not possible to combine UI and Zero Touch nodes in one DLL so you need to use a seperate Solution to build dropdown nodes.
It only works if the DLL is loaded via a package, not with the ‘import library’ function.
You can download a sample Visual Studio Solution below (without de compiled DLL file). Two classes are available. One to create a dropdo…
That’s really helpful, Thanks a lot
Best regards
