Hi Everyone
I have a node python script , I want to add a new wire material, I know that I need to retrieved From Electrical Setting instead from the Revit project here is my script.
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB.Electrical import *
app = uiapp.Application
output = []
#######OK NOW YOU CAN CODE########
Collector1 = FilteredElementCollector(doc)
Filter1 = Collector1.OfClass(ElectricalSetting)
ElectricalSetting = Filter1.ToElements()
Collector = FilteredElementCollector(doc)
Filter = Collector.OfClass(WireMaterialType)
Wiretype = Filter.FirstElement()
Names = "NEC-310-A3"
Error = None
try:
AddWMT = ElectricalSetting.AddWireMaterialType(Names.AsString(), Wiretype)
output.append(AddWMT.ToDSType(True))
except:
TaskDialog.Show("Error Material Type", Error)
#output.append(ElectricalSetting)
# Place your code below this line
OUT = output
my problem is when I run the node say empty list as the output
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
Output = []
Elec = ElectricalSetting.GetElectricalSettings(doc)
Error = None
WireMat = WireMaterialType()
Names = "NEC-210-3A"
try:
NewMaterial = Elec.AddWireMaterialType(Names, WireMaT)
Output.append(NewMaterial.ToDSType(True).Name)
except:
OUT = Output
I modified my code now have this error
can someone please tell me what I am doing wrong thank you.
Hello @jguevara5PPA8
you need to use a baseWireMaterialType to Create a new one
import sys
import System
#import Revit API
Output = []
WireMaT = next((x for x in Elec.WireMaterialTypes if x.ToDSType(False).Name == IN[0]), None)
if WireMaT is not None:
try:
except:
Output.append("WireMaterialType '{}' already exist".format(Names))
OUT = Output
Hi @c.poupin thank you for your help. I really appreciate
