Hi all, am i doing something silly here?
Im just trying to find the items that are ‘Air Terminals’. They are all air terminals, so why do i get ‘false’?
Thanks for help
Since you are comparing string values, use List.Contains instead of equal node.
Try using String.Contains
@johnbim ,
intresting with designscript it works… ![]()
import sys
clr.AddReference('RevitAPI')
clr.AddReference('System')
# 1️⃣referenced docs
# 2️⃣ collector
collector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_PipeCurves)
all_pipes = collector.WhereElementIsNotElementType().ToElements()
# 3️⃣ Categories
cat = [i.Category.Name for i in all_pipes]
OUT = all_pipes, cat
#✅End
KR
Andreas
What is the error you are getting with the string contains node?
Ice changed the structure of my whole script to avoid this problem. Thanks guys for the help anyway.
