Hi guys,
I am creating a script and I need a while loop in a code block
I don’t know how to do that but I have a bit knowledge of coding so I reached the following loop;
Can anyone please help me with the syntax and the wrong phrases
Thank you
Hi guys,
Thank you
Have you read the Dynamo DesignScript documentation: Dynamo DesignScript Learning Resources
I would start there and create a really simple while loop then scale it up. Just reviewing your code (also, please post a copy of your code as you’ll get more answers):
LI instantiation appears to be wrong, use LI={};
P=List.AddItemToEnd(P,LI) is also wrong as you are assigning a list object to P (which is a Polycurve). You should be adding this to LIThank you @Thomas_Mahon for replying
I had a look at the first pdf before , and the second one is very helpful thank you
I fixed these problems you mentioned but I still receive error in the codeblock
this is my script:
def ST(N,L,P1,P2,S,V1,V2)
return=[Imperative]
n=0;
LI={};
while(n<N)
PT1=P1.Translate(V1,(L[n]-1)*S);
PT2=P1.Translate(V1,(L[n+1]-1)*S);
PT3=P2.Translate(V2,(L[n]-1)*S);
PT4=P2.Translate(V2,(L[n+1]-1)*S);
L1=Line.ByStartPointEndPoint(PT1,PT2);
L2=Line.ByStartPointEndPoint(PT2,PT3);
L3=Line.ByStartPointEndPoint(PT3,PT4);
L4=Line.ByStartPointEndPoint(PT4,PT1);
P=PolyCurve.ByJoinedCurves({L1,L2,L3,L4});
LI=List.AddItemToEnd(P,LI);
n=n+2;
return=LI;
It seems that I cannot use L and an input parameter when I changed it to LL it worked perfectly but I don’t know why!!
Anyway thank you
