What coding language to use for coding blocks?
Hello
I’m only starting learning dynamo and I’m using dynamo’s example files to learn.
I noticed in one example to make a List a Node was used
The next file, to make the same list a code block was used.
My question is
What coding language is used by dynamo? and to what extent do I need to learn it?
And what is your opinion for using nodes vs code blocks?
Thank you
Here is the DesignScript Documentation,
DesignScriptGuideV2.1.pdf (343.2 KB)
