Web scraping/parsing/crawling
Hey.
I’m doing web parsing/scraping/crawling using python in VS Code via BeautifulSoup library.
Is it possible to do the same thing using python node in dymamo?
If yes, can i copy paste the python code from VS to dynamo? Or there’s some difference in the libraries?
I believe that should be doable but I haven’t tried it myself.
There are some differences in syntax between VS and IronPython or Python.net, so you’ll have to modify things but the base concepts should work.
BeautifulSoup is a pure Python library (and compatible 2.7), so it is compatible with both Python engines
example with IronPython2
example with CPython3 + PythonNet
here is another solution without external library with the Microsoft mshtml module
example with CPython3 + PythonNet and IronPython2
thanks poupin, that solves things for me, will be seeking help if needed! :heart_eyes:
