Warning script
Hi all, i want to make our companyworksets by using Dynamo. I’ve got help from AI gemini 2.0 Pro but there is a line not correct and giving a warning while not execute what i want.
NameError : name ‘Documentmanager’ is not
defined [’ File “”, line 22, in \n’]
I am getting the warning on this line: doc = DocumentManager.Instance.CurrentDBDocument
Importeer de benodigde Revit API libraries
clr.AddReference(‘RevitAPI’)
workset_names = [
“50_SPA”,
“52_HWI”,
“52_VWI”,
“53_TWI”,
“55_KLI”,
“56_CVI”,
“57_MVI”,
“LF_BWK”,
“LF_CNS”,
“LF_ADV”,
“LF_ELT”,
“LF_XXX”
t = Transaction(doc, “Maak Worksets”)
t.Start()
existing_worksets = FilteredWorksetCollector(doc).OfKind(WorksetKind.UserWorkset)
existing_workset_names = [ws.Name for ws in existing_worksets]
for name in workset_names:
try:
# Controleer of de workset al bestaat
if name not in existing_workset_names:
Workset.Create(doc, name)
print(“Workset ‘{}’ aangemaakt.”.format(name))
print(“Workset ‘{}’ bestaat al.”.format(name))
except Exception as e:
    print("Fout bij het aanmaken van workset '{}': {}".format(name, e))
t.Commit()
Output
OUT = “Worksets aangemaakt/gecontroleerd.”
Maybe someone sees what i did wrong?
Thx in advance,
Regards Tim
clr.AddReference('RevitAPI')
# Get the active Revit document
# List of workset names to create
workset_names = [
    "50_SPA",
    "52_HWI",
    "52_VWI",
    "53_TWI",
    "55_KLI",
    "56_CVI",
    "57_MVI",
    "LF_BWK",
    "LF_CNS",
    "LF_ADV",
    "LF_ELT",
    "LF_XXX"
# Start the transaction
t = Transaction(doc, "Maak Worksets")
t.Start()
# Collect existing user worksets
# Collect output messages
messages = []
    try:
        # Check if the workset already exists
            messages.append("Workset '{}' aangemaakt.".format(name))
            messages.append("Workset '{}' bestaat al.".format(name))
        messages.append("Fout bij '{}' : {}".format(name, str(e)))
# Commit the transaction
t.Commit()
# Return the messages to the Dynamo OUT port
OUT = messages
Thank you! So clr.AddReference(‘RevitServices’) was the thing that was missing?
Yes you were missing that.
I changed the quotes too.
Also you were missing an except (always need one with a try)
