Missing something very fundamental here…
TYPE==TYPE shoudl be true???
import sys ##Standard system input
import Revit ##REvit DB
import Autodesk.Revit.DB as ARDB ##ARDB Namespace
import Autodesk ##Autodesk namespace
from Autodesk.Revit.DB import FilteredElementCollector #FEC fast select
from Autodesk.Revit.DB import LogicalAndFilter ##Combine filters for level + Walls
#from Revit.Elements.Views import * ##.FloorPlanView
from RevitServices.Persistence import DocumentManager ##Doc for active view
from RevitServices.Transactions import TransactionManager ##Trans to commit and undo actions
def Main(doc):
ViewActive = doc.ActiveView
return ViewActive.GetType(), Autodesk.Revit.DB.ViewPlan, (ViewActive.GetType() == Autodesk.Revit.DB.ViewPlan)
doc = DocumentManager.Instance.CurrentDBDocument ##Current Document
OUT=Main(doc)
