Hi Guys I am trying to figure out why I can’t Add a View Filter.
But if i set the View Template to “None”. It works.
I Need to make this work. Please Help
This happens if I apply a view template and then run dynamo.
Thanks!
Hi @ryujinn,
It seems very logical to me.
It exactly the same in Revit. If you applied a view Template on a view, you can’t add a filter.
You have to edit the view template to add the filter.
Input your View Template in View.SetFilterOverrides node instead of your Floor plan view .
Hi Alban,
Thank you!!! Makes perfect sense!
Its working now
Cheers!!
