I used the code below to update an interior elevation view. However, the view break updates according to the values shown in Image 1, whereas I want the view break to match the position shown in Image 2.
Below is the code I used to apply the view break.
If anyone has a solution or can review the code, please let me know where I’m making a mistake.
RevitNodes for Dynamo-Revit element conversion
RevitServices for document access and transaction management
Revit API
clr.AddReference(“RevitAPI”)
Document reference
— INPUT —
Unwrap the view input from Dynamo
view = UnwrapElement(IN[0])
Define split parameters
Each split is defined by (startParam, endParam)
split_top_val = [0.25, 0.625]
split_bot_val = [0.5, 0.75]
— PROCESS —
Begin transaction
try:
# Get crop region shape manager
crop_manager = view.GetCropRegionShapeManager()
# Remove any existing vertical splits
crop_manager.RemoveSplit()
# Apply new vertical splits
for start_param, end_param in zip(split_top_val, split_bot_val):
# Always split region at index 0 (initial crop region)
crop_manager.SplitRegionVertically(0, start_param, end_param)
result = "Splits applied successfully."
except Exception as e:
result = f"Error: {str(e)}"
End transaction
— OUTPUT —
OUT = (view, result)
