Good morning everyone.
I will greatly appreciate your support.
I am trying to be able to load all the RVT files from my root folder to my current REVIT document, I have no idea if there is any node that allows me to perform such an action or maybe someone knows of some code in python that I can use,
I leave a reference image on what I try to do.
Thank you.
Yes Revit API supports linking revit models I think. Genius Loci likely has some nodes in this space, give it a check.
Something like this might work for you.
The Morpheus package Contians the Link Original, and other linking option nodes.
Python Script - by Jonathan ATGER & Nicklas Østertgaard
# part of the code originally created by Nicklas Østertgaard nvo@bimshark.com / nvo@shl.fk and/or Augusto Goncalves (AEC Devblog)
# Workset management, loop, pin and site location settings by Jonathan ATGER (jonathan.atger@yahoo.fr)
# Import RevitAPI
clr.AddReference("RevitAPI")
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
import System
# Start Transaction
# number of elements
try :
numworksets = len(IN[1])
except :
if IN[1] : numworksets = 1
else : numworksets = 0
if isinstance (IN[0], str) :
numlinks = 1
else :
try : numlinks = len(IN[0])
except :
try : numlinks = len([IN[0]])
except :numlinks = 0
#check list lengths
if numlinks != numworksets :
listlength = False
else :
listlength = True
def linkmodel (fpath, options, doc, pin) :
# Create the Revit Link Type
mp = ModelPathUtils.ConvertUserVisiblePathToModelPath(fpath)
lnkOp = RevitLinkOptions(options)
loadedLnkType = RevitLinkType.Create(doc, mp, lnkOp)
# Create the Revit Link Instance
global lnkInstance
lnkInstance = RevitLinkInstance.Create(doc, loadedLnkType.ElementId, ImportPlacement.Origin)
#Pin link
lnkInstance.Pinned = IN[2]
try:
# Number of worksets input and filepaths input are different
if IN[1] and listlength == False :
OUT = "The number of worksets doesn't match the number of links"
# Multiple Worksets input
elif IN[1] and listlength == True and numlinks !=1 :
#Get WorksetTable and current workset
wstable = doc.GetWorksetTable()
activewsid = wstable.GetActiveWorksetId()
#Create list for output
links = []
for fpath, ws in zip(IN[0], IN[1]) :
# Get WorksetId
wssimpleid = ws.Id
wsid = WorksetId(wssimpleid)
# Set the workset
WorksetTable.SetActiveWorksetId(wstable, wsid)
# Create the Revit Link Type and Link Instance
linkmodel(fpath,"", doc, IN[2])
#add created link to output
links.append(lnkInstance)
#reset current workset
WorksetTable.SetActiveWorksetId(wstable, activewsid)
#output
OUT = links
# Single workset input
elif IN[1] and listlength == True and numlinks == 1 :
links = []
wssimpleid = IN[1].Id
linkmodel(IN[0],"", doc, IN[2])
OUT = links
# No worksets input
elif numlinks != 1 :
links = []
for fpath in IN[0] :
OUT=links
else :
links = []
OUT=links
except:
# if error accurs anywhere in the process catch it
import traceback
errorReport = traceback.format_exc()
OUT = errorReport
# End Transaction
You need to ensure the object returned by the inout is always a list of files, not a single file.
Adding a ToList method acting on the input should resolve the issue. There are number plus examples in the forum, silo I recommend doing a search and catching the results there.
Alot of the nodes in the crumple package have python for the tolist method, try unpacking some of those and see how you go ![]()
