Ungrouping & Purging All Families in a Model
I found some time to take a look at the reloading:
The IFamilyLoadOptions implemented in python:
class FamilyOption(IFamilyLoadOptions):
	def OnFamilyFound(self,familyInUse,overwriteParameterValues):
		overwriteParameterValues = True
		return True
	def OnSharedFamilyFound(self, sharedFamily, familyInUse, FamilySource, overwriteParameterValues):
		return True
Here is the call of the LoadFamily method call on the familydocument:
famdoc.LoadFamily(doc, FamilyOption())
@luisa Do you want to test the script? It doesn’t purge anything, because that has to be done manually. There is no API call to the purge command in Revit.
OpenAndUngroupFamilies.dyn (6.1 KB)
For anyone that might be interested,.the complete python script:
clr.AddReference('System')
		return True
		return True
#Preparing input from dynamo to revit
families = UnwrapElement(IN[0])
for f in families:
	famdoc = doc.EditFamily(f)
	fec = FilteredElementCollector(famdoc).OfCategory(BuiltInCategory.OST_IOSModelGroups).WhereElementIsNotElementType()
	if fec.FirstElement() is not None:
		groups = fec.ToElements()
		TransactionManager.Instance.EnsureInTransaction(famdoc)
		[g.UngroupMembers() for g in groups]
		#famdoc.SaveAs(path +"\\" + e.Name + ".rfa")
OUT = 0
