True/false if list has duplicate
Hey All,
I’m having some hard time to figure out, I know the answer will be easy as pie :slight_smile:
I have a list and I need boolean if the sublist has duplicate element.
See image below. So if the date is there two times in sublist it should be true (or false, doesn’t matter) so I can filter sheets where revision is wrong.
Thanks :slight_smile:
date
You could use List.UniqueItems and List.Count and then compare the lists lengths
@daninet An illustration of the above suggestion by @Yna_Db
thanks guys it worked :beer::beer:
