I am attempting to create a script to gather a few predefined 3d views as well as all sheets that appear in sheet list and create a sheet set of those views/sheets. I want to use that set to define what views/sheets are published to the BIM 360 web viewer. I have the script collecting the correct views and sheets and checking the boxes for them in the publish settings, the issue I have is that whenever I run the script the check box to include the set in the publish settings gets turned off. I have manually checked the box to include the set and saved but when I run the script the set is unselected. I attached screenshots of the check box I want to control as well as the script I am using. I am new to Dynamo and can’t find a solution, any suggestions would be appreciated.
Related topics
Topic | Replies | Views | Activity | |
BIM360 Publishing Settings | 1 | 34 | December 17, 2024 | |
[ACC] Select Sets accessible in Dynamo? | 2 | 410 | January 29, 2023 | |
View Sets to Publish | 2 | 1079 | September 3, 2022 | |
Creating Revit Publish Sets for ACC | 3 | 208 | March 27, 2024 | |
Publishing to BIM 360 | 1 | 775 | March 30, 2022 |
