Trailing Zeros when importing info from Excel
Hi All, I am trying to remove the trailing zeros.000 out of some numbers I have extracted from an Excel. So far I have tried Split, string.remove, (spring nodes) Number.tostring and a few attempts at python. I literally cannot figure out how to do it.
This is the culprit. there are no nulls in the script. The reason I am using String remove is to remove a ] that was at the back of all the numbers in the last list.
any help most appreciated.
Map Autodesk Build to Revit.dyn (36.0 KB)
@johnny.buccolaY4MEH unfortunately your image is not legible, so could you please let us know what you’re trying to do?
Are you looking to use these numbers as a String? Or as a Number? Where do you want to put them?
I am looking to remove the .000 from the rear end of the string list marked-up in the image. As mentioned they have been extracted from an Excel.
let’s try with small python script like this :slight_smile:
import sys
import re
str = IN[0]
pattern = re.compile(r'\.000')
# Place your code below this line
OUT = [re.sub(pattern, '', i) for i in str]
Many Thanks!! but no ball I’m afraid.
Hello @jonny.pyeHMSQY - What version are you in? There was a visual bug that crept into one release that you may be experiencing. If so, this is purely visual and won’t affect the data as it traverses your graph.
I think I’m right in saying that the bug was patched with Dynamo 2.19 shipped with the Revit 2024.2 update right @solamour ?
If you’re in Revit 2024.1 @jonny.pyeHMSQY I’d recommend the update (not only for this but the other improvements included within this version).
There’s two things at play here:
  1. The String From Object node has always returned trailing zeros, as you can see in this screenshot from the Dynamo 2.9 release. We can :100: talk about changing this default beahvior :slight_smile:
  1. The bug in question was about how many trailing zeros there were that we had tethered to your Number Format in the Preferences Panel unintentionally - which caused issues with understanding accuracy if you had it set to 0 or 0.0 and rounding.
  1. The data itself transmits successfully in all cases as shown below - it’s purely a visual bug. Quite an annoying one for sure, but it’s not destroying your data :pray: You can see this here by rehydrating the string into a number and seeing it accurately give the decimally placed number.
Yep that was it, thank you :slight_smile:
I like that phrase, poor thirsty string haha.
I for one would love to change that functionality. It seems logical that when returning a string version of a float you would expect the number of decimal places shown in the float to match the relevant output string…
Worth taking this discussion elsewhere?
I’ll just log in in-house in JIRA :slight_smile: It’s a sensible change. One of our goals over the past ~3 years has been “Removing the magic” which is basically making what is expected happen. In this case, you don’t expect trailing zeros.
Great stuff. I’ll add this to the list of things that I can say to people in my old man voice “Back in my day…”
yeah, my proposal is to modify the string from nodes to add an input for standard c# format strings.
The options we offer for numeric preview in preferences will always be limited, and sporadic compared to giving the graph author control - plus, IMO an application level display setting should not be involved at all in generation of actual data / graph execution behavior.
Hi! It seems like you’ve encountered a challenge with removing trailing zeros from numbers extracted from Excel. One approach to consider is using the ‘String.TrimEnd’ method in Python to eliminate trailing zeros. Here’s a sample code snippet:
def trim_zeros(input_list):
return [str(int(float(num))) if ‘.’ in num else num for num in input_list]
Example usage:
input_numbers = [‘1.000’, ‘2.500’, ‘3.120’, ‘4’]
output_numbers = trim_zeros(input_numbers)
Result:
output_numbers = [‘1’, ‘2.5’, ‘3.12’, ‘4’]
This code converts each number to a float, removes trailing zeros, and then converts it back to an integer if it’s a whole number. Adjust it according to your Dynamo script’s requirements. Hope this helps!
Oh hello ChatGPT :wave: :laughing:
