I am trying to get all surfave “points/vertices” within a border polyline.
When checking the civil docs it i found the following method: GetVerticesInsideBorder Method (autodesk.com)
sadly when using it i get the error mentioned in the title.
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
surfaceIN = IN[0]
border = IN[1]
#vertices = surfaceIN.GetVerticesInsideBorder(border)
OUT = vertices
