I’ve found C#
has a switch case
, I don’t remember if Python
does too, and I see a node for if else
logic. I was just wondering if anyone has made a Dynamo Node
for a Switch Statement?
C# Case Statement : Switching Between Multiple Cases - Udemy Blog
The core equivalent is if, elif, else logic.
But there are a few different methods described on Stack that can be translated into the Dynamo environment for IronPython and CPython3.
Do you have a specific use case you are looking at?
I know there’s one coming up soon, just trying to do my prep work ahead of time, specifically I’ll be filtering through 59 drafting views, horizontal and vertical are a huge filter, but not the only case
to be expected, I’ll see if I can start with something like
def f(x):
match x:
case 'horizontal':
return 1
case 'vertical':
return 2
case _:
return 0 # 0 is the default case if x is not found
and then I can add to it as they become clearer
That’s better than I had in mind, thanks mate!
