Hey.
I’m trying to make a solid by thicken a surface, but the 2 nodes i know of, Surface.Thicken, either put the solid in the middle of the surface or on top, i want to put it under the surface. Any ideas on how this i done??
Nichlas
Hey.
Nichlas
Hi Nichlas,
You can check which direction the surface is pointing by looking at the surface normal. The thickening will follow the normal of the surface, which mean you need to reverse the normal, if its pointing upwards.
Surface.Normal is the node you’re after here, if im not mistaken.
Great
