Is there a way to get the superelevation data and translate that to an offset alignment profile cross slope regions?
I haven’t seen a node out there to do this, so you’d need to make one yourself with Python or C#. The relevant classes would be Profile.OffsetProfileParameters and Profile.OffsetProfileParametersStation. There are settable properties for the station and slope.
I tried to do that, but I know little of python and API, but found this class you said.
https://help.autodesk.com/view/CIV3D/2021/ENU/?guid=d9005f8a-b288-254d-0402-497b6eaa7fe5
You can try this in a Python Script node:
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('Civil3DNodes')
clr.AddReference('System')
# Import references for Dynamo for Civil 3D
from Autodesk.Civil.DynamoNodes import Alignment as DynAlignment
dataEnteringNode = IN
editor = adoc.Editor
civdoc = CivilApplication.ActiveDocument
align = IN[0]
station = IN[1]
slope = IN[2]
result = []
oppsset = []
def offsetsuper(align,station,slope):
global adoc
global editor
global civdoc
try:
with adoc.LockDocument():
with adoc.Database as db:
#Selected alignment ID and object
alignment = align
alignmentId = alignment.InternalObjectId
al = t.GetObject(alignmentId, OpenMode.ForRead)
alname = al.Name
#Profile ID and object
profileId = al.GetProfileIds()[0]
profile = t.GetObject(profileId, OpenMode.ForWrite)
profilename = profile.Name
#get and clear existing parameters
opp = profile.OffsetProfileParameters(profile)
oppstations = opp.Stations
oppstations.Clear()
n = station.Count
for i in range(0,n):
slopepercent = slope[i]*0.01
opps = profile.OffsetProfileParametersStation(station[i],slopepercent)
oppsset.append(opps)
oppssetlist = List[Profile.OffsetProfileParametersStation](oppsset)
opp.Stations = oppssetlist
#a = opp.Stations
t.Commit()
except Exception() as ex:
oppstations.append(ex.message)
return oppstations
OUT = offsetsuper(align,station,slope)
It is far from finished, it gets buggy after multiple runs on the same alignment, although it supposedly deletes the parameters first, so use at own risk. On first run, works as intended. You can use superelevation data as input lists.
Thank you kovacsv. I would never be able to do that alone.
