Get this error in Revit 2026.4
@EzDoesIt v. 2025.8.27
Thank you, but it isn’t working with Revit 2026.4
That above screenshot was taken in Revit 2026.4. Please try removing the old node you’re using and adding it again.
General note: if a given package version clearly specifies which version it is compatible with, it should not be reported as an error that the package doesn’t work with a version it wasn’t designed for. Additionally, this is not an error but a warning with fairly clear information.
Thanks, reinstall did it.
It clearly stated that i had the latest version installed so thats where my confusion come from.
Lesson learned for the future
