String.Contains not working, solution needed
Can someone tell me what I am doing wrong, please? It is supposed to give me true/false based on whether it has a value or not, but I am only receiving ‘false’.
Can you provide another example? In that one you’re checking if the string contains "" (which is nothing, hence all strings contains that)
This is the issue. Instead of String.Contains you should check for equality using a == node.
Thank you :slight_smile: that was what I was looking for.
