someone please explain me the difference between Array[str] and list of strings.
I tried to figure it out from Python resources, but I have no idea how to change this, as all examples look like lists.
Also this one causing Dynamo crash as well upon running.
I preferably would not share the code itself as it uses some C3D Beta stuff.
This is basically a property that requires strings as input.
I also tried the array module, but if I understand correctly that is for numeric values.
Thanks.
@kovacsv ,
can you share the code? ![]()
Sorry, I’d rather keep it on the python track.
I was just wondering if is it a Python.NET issue or maybe I do something wrong(more likely).
The .NET required input is string[ ].
Hello @kovacsv
maybe can you show only lines 45 to 50 of code (or less)
Try this.
from System import Array
list = IN[0]
array = Array[str](list)
You’d use array (or whatever you call the variable) in the method call that expects string[].
Thanks, that worked.
