I
found the way how to sort the x point of element in ascending order.but I wonder how to sort the y point in descending in order while maintaining in x point ascending order…
Sorry for my english…
Try doing the sorting in the opposite order of what you want. For example, if you want:
you should do the opposite order, meaning:
See attached:
It looks like it worked, but the Dynamo data is missing some of the data that the excel has. For example, Excel’s row 3 doesn’t look like it exists in the dynamo data.
But for what is in Dynamo, it is sorted first by ascending column D, then by descending column E so it looks like it worked. Can you show where it doesn’t?
Check the data in row D to make sure that there aren’t more places after the decimal you can’t see. It might be ordering to a higher significant digit that you can’t see.
Try with an == or > node. It shouldn’t be able to just reset the sorting after a random amount of items.
Ok. I’ll try. Thanks!
