Sort Numbers
I would like to sort numbers in an order like this:
1.2.8
1.2.9
1.2.10
1.10.12
But with dynamo i get the result:
1.10.12
1.2.10
1.2.8
1.2.9
I will now use the workaround that i use the style like 01.02.03, that works.
Just wanted to ask if there would be any way to sort the list like i wanted to do in first place.
Thanks for any help!
Kind Regards!
@gerhard.p You need something called natural sort.
Try this:
import re
def natural_sort(l):
    convert = lambda text: int(text) if text.isdigit() else text.lower()
    alphanum_key = lambda key: [ convert(c) for c in re.split('([0-9]+)', key) ]
    return sorted(l, key = alphanum_key)
OUT = natural_sort(IN[0])
Alternatively, you can use the Natural Sort node from Orchid package
Natural sort, thats a thing i know now, thank you so much :grinning:
