Hello all,
I’m trying to create a Point3dCollection of the bottom vertices of a Solid3d. However, when I run this script:
for id in boundary_id:
obj = t.GetObject(id, OpenMode.ForRead)
#find half of the vertices of a solid
if isinstance(obj, Solid3d):
brep = Brep(obj)
vertices = brep.Vertices
points_XYZ = []
for i in vertices:
point_vertice = i.Point
points_XYZ.append([point_vertice.X, point_vertice.Y, point_vertice.Z])
points_XYZ.sort(key=lambda x: (x[2]))
points = []
for i in points_XYZ:
point_a = Point3d(i[0],i[1],i[2])
points.append(point_a)
pts = Point3dCollection()
for k in points[0:(len(points)/2)]:
pts.Add(k)
pts.Add(points[0])
boundary_p3dcol.append(pts)
I get the following result: it appears that brep.Vertices results in a unordered list of points
The order of the first list is indicated in red below:
What I want to achieve is the order marked with blue: the Point3Ds are sorted clockwise.
If the point are sorted clockwise a closed polygon can later on be created for bounding a volume surface.
