Sort a list of points with difference between the coordinates
Sorry, my language is not good
Hello all
If you can help please
Is it possible to get the order of the points as in the attached picture example
Even if there is some slight difference between the coordinates
I found the idea, but if there are no differences between the coordinates, as in the link
I hope I made my point clear
q sort by locatio.dyn (16.7 KB)
Hello…could “list reverse” help you in that case
HI
I used this code
But it needs modification
Any idea to reach the goal as in the example picture
orglst = IN[0]
orglst.sort(key = lambda orglst: (orglst.Y, orglst.X, orglst.Z))
OUT = orglst
Hello @hosneyalaa
I have done this exercise, you can further modify the script as per your requirement
You can further sort the group as per group average.
HI @honeyjain619
please
attach the code
Hello @hosneyalaa
Home11.dyn (24.0 KB)
THANK YOU
@honeyjain619
