[solved] How test and manipulate family instance by id?
FacingOrientation is both a node in Dynamo and the name of a property in the Revit API which is why it works.
Thank Cgartland, you give me the ultimate indice :smile:
REVIT API / Location Class
code :
clr.AddReference('RevitAPI')
dataEnteringNode = IN
#var
moa = []
test = "false"
param = []
# procedure #
idelem = "13974"
id = ElementId(int(idelem))
element = doc.GetElement(id)
element = UnwrapElement(element)
if element :
    test = "true"
vec=element.FacingOrientation
position=element.Location.Point
origi=doc.GetElement(id).Location.Point
#position=element.Point.ToPoint()
moa.append([element, test, vec, position, origi])
OUT= moa
