SheetSetMgr.SheetSetManager 操作失败。
Retrieving the COM class factory for component with CLSID {BCFA0AB8-CEFC-43E9-841B-8141F44FE240} failed due to the following error: 80040154 没有注册类 (0x80040154 (REGDB_E_CLASSNOTREG)).
The package hasn’t been updated for 2027 yet.
It’s on my list but it’s been lower on the priority this year, it just hasn’t bubbled to the top yet.
Looking forward to updating soon!!That really means a lot to me
Hi Adam, really appreciate the sheet set manager add-on and the demonstration I’ve seen of you walking through it on youtube! You may not know the answer to this, but do you think some of the things that sheet set manager could be mimicked using Python in Dynamo? My work is swapping to C3D 2027 soon and the sheet set manager is the saving grace on our large plan sets. So I’d be hoping to set up something temporarily until you can get it updated for 2027. Wasn’t sure if sheetset manager is accessing things in the C3D API that the Python node wouldn’t be able to reach.
Thanks!
This package is using the Sheet Set API files that ship with AutoCAD and all verticals. The problem for me is that each new release has those API files incremented, even though none of them change (and haven’t changed in 20 years).
You might be able to replicate the work with Python, but you’d have to reference those API files directly to use in your python nodes. If you’re doing it that way, you’d probably be better off writing a whole node that does all the steps for you, rather than trying to emulate the individual nodes I have. This is just because there’s so many steps that are done in the background for each and every read/write to properly lock the database for those edits. You’d end up replicating code in every node and then having maybe 5 lines of original code per node.
I see I see, do you happen to have a github where the AMR sheetset manager files are hosted/is it open source? It’s used so much at my work I would honestly be down to take a look at how it’s built to see if I can take a crack at it, especially if it is just incrementing some API files (as tedious and annoying as it sounds). Totally understandable if not, but figured I’d check!
Yes, it’s a public repo at GitHub - AdammReilly/AMR_dynSSetMgr · GitHub
I’ve finally made some headway on updating this package. However, because I had started the versioning based on the supported AutoCAD version, I can’t backtrack that without deprecating the package and starting over. Since there’s over 5k downloads I opted to just keep the versioning at 2025 and stepped the minor to 4.
I’m rebuilding the overall project to remove direct dependencies on any specific CAD versions. Since Autodesk switched away from Framework with the 2025 version, I’m also dropping direct support for anything before 2025. That’ll also simplify maintenance a little more and ties into keeping the 2025 major version code.
I’m still testing changes for now, but anyone else that wants to try it out can pull the repo from GitHub and build it for your version of C3D.
