Sheet Names according to BIM naming convention
I am pulling some project information data to combine it with the data from code block into one line sheet name string, separated with"-". Could you advise what nodes will help me to get that? (to look like in Sheet Name sample)
Hello, here is a solution (certainly improvable)
9 juillet forum anglais reponse 2.dyn (28.9 KB)
Cordially
christian.stan
Thank you! that creates the name exactly as I wanted. But, can I feed it into the next one?
This error is bizarre, the string is definitely not null.
This actually works now.
