Hi Rahmeni,
Please read the following post How to get help on the Dynamo forums
There are know issues with Excel and Dynamo try the alternative Data.OpenXMLImportExcel node (see also here)
Screenshots with information pinned also assists the forum members understand your problem
Also I would look for a Revit add in to transfer shared parameters if that is your intent
Onto your graph…
The list clean / transpose breaks the information - you will need to fix the Excel
Looking at the Excel
Repeated names will possibly create multiple shared parameters with different GUIDs
Fix the blanks
Remove the header (Row 1 in Excel)
This will not work
What I would suggest is that you will need to build some dictionaries
Example
Make sure your group names are in the current shared parameter file
