I could’t run setparameterbyname. I want change shared parameter value on excel and import to revit. “number” and “name” parameters work well, they aren’t shared parameter but shared parameters don’t work when import to revit from excel. Also shared parameters and other parameters work well when export to excel from revit.
For parameter name you are putting values into the parameter name? You are also missing a lot of element inputs.
I am getting error message “No parameter found by that name.” when match element inputs. But it is correct parameter name.
See Attached Image - This applies to all of the other SetParameterNodes as w
ell…
Im getting another error message “The parameter’s storage type is not a number.
Element.SetParameterByName operation failed.” I changed format cells to number on excel but didn’t work
