Set Grid Extents and Bubbles
Hello @c.poupin :slight_smile:
By adding an output of grid angle to your code i could make the process of setting the bubbles much more efficient :smiley:
This is now the exact result i want:
ezgif.com-gif-maker
from RevitServices.Persistence import *
clr.AddReference("RevitAPI")
app = uiapp.Application
uidoc = DocumentManager.Instance.CurrentUIApplication.ActiveUIDocument
if isinstance(IN[1], list):
	gridList = UnwrapElement(IN[0])
	viewList = UnwrapElement(IN[1])
	angleList = UnwrapElement(IN[2])
	gridList = [UnwrapElement(IN[0])]
	viewList = [UnwrapElement(IN[1])]
	angleList = [UnwrapElement(IN[2])]
for grids, angles, view in zip(gridList, angleList, viewList):
	for grid, angle in zip(grids, angles):
		if 121< angle <300:
			grid.ShowBubbleInView(DatumEnds.End1,view)
			grid.HideBubbleInView(DatumEnds.End0,view)
			grid.ShowBubbleInView(DatumEnds.End0,view)
			grid.HideBubbleInView(DatumEnds.End1,view)
doc.Regenerate()
OUT = viewList
import math
import Autodesk.DesignScript.Geometry as DSGeo
#import Revit API
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
sdkNumber = int(app.VersionNumber)
def createDatumLine(boundLines, grid):
	gridLine = None
	curveG = grid.Curve#.ToProtoType()
	vectGrid = curveG.Direction
	lstPtToLine = []
	for lineBound in boundLines:
		rayc = DB.Line.CreateUnbound(XYZ(curveG.Origin.X, curveG.Origin.Y, lineBound.GetEndPoint(0).Z) , vectGrid)
		outInterR = clr.Reference[IntersectionResultArray]()
		result = rayc.Intersect(lineBound, outInterR)
		print(result)
		if result == SetComparisonResult.Overlap:
			interResult = outInterR.Value
			lstPtToLine.append(interResult[0].XYZPoint)
	print(lstPtToLine)
	if len(lstPtToLine) == 2:
		P1 = lstPtToLine[0].ToPoint()
		P2 = lstPtToLine[1].ToPoint()
		TransXYZ1 = Geometry.Translate(P1 ,0,0,0)
		TransXYZ2 = Geometry.Translate(P2 ,0,0,0)
		TransPoint1 = TransXYZ1.ToXyz()
		TransPoint2 = TransXYZ2.ToXyz()
		gridLine = Autodesk.Revit.DB.Line.CreateBound(TransPoint1, TransPoint2)
	return gridLine
activView = UnwrapElement(IN[0])
lstInputViews = UnwrapElement(IN[0])
for activView in lstInputViews:
	activView.CropBoxVisible = True
	doc.Regenerate()
	cropBox = activView.CropBox
	fecGrids = FilteredElementCollector(doc, activView.Id).OfClass(DatumPlane).ToElements()
	cutOffset = fecGrids[0].GetCurvesInView(DatumExtentType.ViewSpecific, activView)[0].GetEndPoint(0).Z
	fecGrids = [x for x in fecGrids if isinstance(x, DB.Grid)]
	outLst = []
	newGLineList = []
	shpManager = activView.GetCropRegionShapeManager()
	boundLines = shpManager.GetCropShape()[0]
	if activView.ViewDirection.IsAlmostEqualTo(XYZ(0,0,1)):
		# get Current Elevation of boundLines
		currentZ = list(boundLines)[0].GetEndPoint(0).Z
		# transform boundLines CurveLoop
		tf = Transform.CreateTranslation( XYZ(0,0, cutOffset - currentZ))
		boundLines = CurveLoop.CreateViaTransform(boundLines, tf)
		for grid in fecGrids:
			outLst.append(grid.Curve.ToProtoType())
			newGLine = createDatumLine(boundLines, grid)
			newGLineList.append(newGLine)
			if newGLine is not None:
				grid.SetCurveInView(DatumExtentType.ViewSpecific, activView, newGLine)
startpointList = []
endpointList = []
rotationAngleList = []
for newGLine in newGLineList:
	startpointXYZ = newGLine.GetEndPoint(0)
	endpointXYZ = newGLine.GetEndPoint(1)
	startpoint = startpointXYZ.ToPoint()
	endpoint = endpointXYZ.ToPoint()
	startpointList.append(startpoint)
	endpointList.append(endpoint)
	vector = newGLine.Direction
	rotationAngle = abs(math.degrees(vector.AngleOnPlaneTo(XYZ.BasisX, XYZ.BasisZ)))
	rotationAngleList.append(rotationAngle)
OUT =  lstInputViews, startpointList, endpointList, rotationAngleList
