Set footings Type using WPF
Hi All, @c.poupin
I’m implementing a pyrevit tool using MVVM (the logic may be similar when using Dynamo) that allows the user to select the desired Footing Type from a combobox dropdown list for each grid intersection point. For now, I’m focusing on assigning a Footing Type Instance to each position corresponding to an intersection point.
As you can see in the example below, the positions (i.e., intersection points) are correctly displayed in the UI, and I can add Footing Type Instances each time I click the Ajouter button. However, when I select a Type Instance for each position from the combobox dropdown lists, an exclamation mark appears for each selection. Additionally, I cannot determine whether those instances have been selected correctly because no message is printed when I click the Appliquer button.
Remark: In the Types comboboxes, I want to display the Name property for each FootingType instance while storing those instances for later use in the code. That’s why I used DisplayMemberPath="Name" in the xaml layout.
Please check my references below:
xaml layout
<Window
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    Title="Footings"
    Height="Auto" Width="460"
    SizeToContent="Height"
    ResizeMode="NoResize"
    WindowStartupLocation="CenterScreen">
    <Grid Margin="10">
        <Grid.RowDefinitions>
            <RowDefinition Height="5*"/>
            <RowDefinition Height="85*"/>
        </Grid.RowDefinitions>
        <Grid.ColumnDefinitions>
            <ColumnDefinition Width="50*"/>
            <ColumnDefinition Width="30*"/>
            <ColumnDefinition Width="20*"/>
        </Grid.ColumnDefinitions>
        <TextBlock Grid.Column="1" Grid.ColumnSpan="2" Text="Caracteristiques des semelles" FontWeight="Bold" FontSize="11" />
        <DataGrid x:Name="Symbols" Grid.Row="1" Grid.RowSpan="2" AutoGenerateColumns="False"
                Background="Transparent" GridLinesVisibility="None">
            <DataGrid.Columns>
                <DataGridTextColumn Header="Position" Binding="{Binding Position}" Width="*" />
                <DataGridTemplateColumn Header="Type de Semelle" Width="2*">
                    <DataGridTemplateColumn.CellTemplate>
                        <DataTemplate>
                            <ComboBox x:Name="Types" ItemsSource="{Binding LstTypes}"
                                      SelectedItem="{Binding SelectedType, Mode=TwoWay, UpdateSourceTrigger=PropertyChanged}"
                                      DisplayMemberPath="Name">
                            </ComboBox>
                        </DataTemplate>
                    </DataGridTemplateColumn.CellTemplate>
                </DataGridTemplateColumn>
            </DataGrid.Columns>
        </DataGrid >
        <StackPanel Grid.Row="1" Grid.Column="1">
            <Label Content="Longueur :" VerticalAlignment="Center" Width="75" HorizontalAlignment="Left"/>
            <DockPanel>
                <TextBox x:Name="long_value" Height="20" Width="75" VerticalContentAlignment="Center" Margin="5,0,0,0"/>
                <Label Content="cm"/>
            </DockPanel>
            <Label Content="Largeur :" VerticalAlignment="Center" Width="75" HorizontalAlignment="Left"/>
            <DockPanel>
                <TextBox x:Name="larg_value" Height="20" Width="75" VerticalContentAlignment="Center" Margin="5,0,0,0"/>
            </DockPanel>
            <Label Content="Epaisseur :" VerticalAlignment="Center" Width="75" HorizontalAlignment="Left"/>
            <DockPanel>
                <TextBox x:Name="ep_value" Height="20" Width="75" VerticalContentAlignment="Center" Margin="5,0,0,0"/>
            </DockPanel>
        </StackPanel>
        <StackPanel Grid.Row="1" Grid.Column="2" Orientation="Vertical">
            <Button Content="Ajouter" Width="85" Click="Add_Click" VerticalAlignment="Top" Margin="0,30,0,10"/>
            <Button Content="Supprimer" Width="85"  VerticalAlignment="Top" Margin="0,20,0,10"/>
            <Button Content="Supprimer tous" Width="85"  VerticalAlignment="Top" Margin="0,20,0,10"/>
        </StackPanel>
        <StackPanel Grid.Row="2" Grid.Column="1" Grid.ColumnSpan="2">
            <Label Content="Contrainte de Béton :" VerticalAlignment="Center"/>
            <DockPanel>
                <TextBox x:Name="contrainte_value" Height="20" Width="75" VerticalContentAlignment="Center" Margin="5,0,0,0"/>
                <Label Content="MPA" />
            </DockPanel>
        </StackPanel>
        <StackPanel Grid.Row="3" Grid.ColumnSpan="3" Orientation="Horizontal" VerticalAlignment="Center" Width="210" Margin="0,5,0,0">
            <Button x:Name="Appliquer" Click="Appliquer_Click" Content="Appliquer" Width="100"/>
            <Button x:Name="Fermer" Click="Fermer_Click"  Content="Fermer" Width="100" Margin="10,0,0,0"/>
        </StackPanel>
    </Grid>
</Window>
Footing_script
# -*- coding: UTF-8 -*-
import wpf, clr, os, itertools, math
from pyrevit import forms, revit
from System.Windows import Window
from System import Array
from System.Collections.ObjectModel import ObservableCollection
from System.ComponentModel import INotifyPropertyChanged, PropertyChangedEventArgs
from System.Windows.Controls import CheckBox, TextBlock, TextBox, ListBoxItem
from Autodesk.Revit.DB.Structure import StructuralType  # Add this import
uidoc = __revit__.ActiveUIDocument
doc = __revit__.ActiveUIDocument.Document
app = __revit__.Application
results = clr.Reference[IntersectionResultArray]()
class FootingType:
    def __init__(self, d1, d2, d3):
        self.d1 = d1
        self.d2 = d2
        self.d3 = d3
        if d1 < d2:
            self._dim = [d1, d2, d3]
            self._dim = [d2, d1, d3]
    @property
    def H(self):
        return self._dim[0]
    @property
    def W(self):
        return self._dim[1]
    @property
    def T(self):
        return self._dim[2]
    @property
    def Name(self):
        return "{}cm x {}cm x {}cm".format(self.W, self.H, self.T)
    def __eq__(self, other):
        return self.H == other.H and self.W == other.W and self.T == other.T
    def __hash__(self):
        return hash(self.Name)
class ViewModelBase(INotifyPropertyChanged):
    def __init__(self):
        self._property_changed = None
    def add_PropertyChanged(self, handler):
        self._property_changed = handler
    def remove_PropertyChanged(self, handler):
    def notify_property_changed(self, property_name):
        if self._property_changed:
            self._property_changed(self, PropertyChangedEventArgs(property_name))
class Footings_VM(ViewModelBase):
    def __init__(self, Position):
        self._position = Position
        self._types = ObservableCollection[object]()
        self._selected_type = None
    @property
    def Position(self):
        return self._position
    @Position.setter
    def Position(self, value):
        self._position = value
        self.notify_property_changed('Position')
    @property
    def LstTypes(self):
        return self._types
    @LstTypes.setter
    def LstTypes(self, lst_value):
        self._types = ObservableCollection[object](lst_value)
        self.notify_property_changed('LstTypes')
    @property
    def SelectedType(self):
        return self._selected_type
    @SelectedType.setter
    def SelectedType(self, value):
        self._selected_type = value
        self.notify_property_changed('SelectedType')
    def AddType(self, footing_type):
        self._types.Add(footing_type)
class MyWindow(Window):
    def __init__(self):
        script_path = os.path.dirname(__file__)
        xaml_path = os.path.join(script_path, 'footings.xaml')
        wpf.LoadComponent(self, xaml_path)
        self.Data = ObservableCollection[Footings_VM]()
        symbols = self._grids_symbols()
        for s in symbols:
            foot = Footings_VM(s)
            self.Data.Add(foot)
        self.Symbols.ItemsSource = self.Data
    def _grids_symbols(self):
        Symbols = []
        grids = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Grids) \
            .WhereElementIsNotElementType().ToElements()
        for gd_a, gd_b in itertools.combinations(grids, 2):
            curveA = gd_a.Curve
            curveB = gd_b.Curve
            vectA = curveA.ComputeDerivatives(0.5, True).BasisX
            vectB = curveB.ComputeDerivatives(0.5, True).BasisX
            symA = gd_a.Name
            symB = gd_b.Name
            # check if lines are parallel
            if abs(vectA.CrossProduct(vectB).Z) < 0.01:
                # if true go to the next iteration
                continue
            result = curveA.Intersect(curveB, results)
            if result == SetComparisonResult.Overlap:
                if symA.isalpha() and symB.isdigit():
                    symbol = "{}-{}".format(symA, symB)
                elif symA.isdigit() and symB.isalpha():
                    symbol = "{}-{}".format(symB, symA)
                    continue
                Symbols.append(symbol)
        return sorted(Symbols)
    def Add_Click(self, sender, e):
        try:
            # Get values from the text boxes
            long_value = float(self.long_value.Text)
            larg_value = float(self.larg_value.Text)
            ep_value = float(self.ep_value.Text)
            # Create a new FootingType instance
            foot = FootingType(long_value, larg_value, ep_value)
            # Add the FootingType instance to all Footings_VM instances in the Data collection
            for vm in self.Data:
                vm.AddType(foot)
                print("Footing Added: {}".format(foot.Name))  # Debugging
            self.long_value.Clear()
            self.larg_value.Clear()
            self.ep_value.Clear()
        except ValueError:
            forms.alert("Please enter valid numeric values for dimensions.")
    def Appliquer_Click(self, sender, e):
        selected_foot = [vm.SelectedType for vm in self.Data if vm.SelectedType is not None]
        if selected_foot:
            print("Selected Footings: {}".format([foot.Name for foot in selected_foot]))
            print("No footings selected.")
        self.Close()
    def Fermer_Click(self, sender, e):
        self.Close()
def main(doc=None):
    """Main entrypoint for the script."""
    doc = doc or revit.doc
    foundation = MyWindow()
    foundation.ShowDialog()
if __name__ == "__main__":
    main()
How can I fix this issue?
Thanks.
I haven’t tested your code, but the first error I see is that you’ve omitted to initialize the super class (inheritance )
        ViewModelBase.__init__(self) # need to init the super class
I corrected this error and updated the code by adding debug points in the Appliquer_Click function. Then, I tested the code by adding two footing types, and it seems to be working for instance addition. However, no footing is selected, as shown in the output!
console output :
Footing Added: 100.0cm x 100.0cm x 20.0cm
Footing Added: 200.0cm x 200.0cm x 20.0cm
updated code
class FootingType:
        self.d1 = d1
        self.d2 = d2
        self.d3 = d3
        if d1 < d2:
    @property
    def H(self):
        return self._dim[0]
    @property
    def W(self):
        return self._dim[1]
    @property
    def T(self):
        return self._dim[2]
    @property
    def Name(self):
    def __hash__(self):
    def __init__(self):
        self._selected_type = ""
    @property
    def Position(self):
    @Position.setter
    @property
    def LstTypes(self):
        return self._types
    @LstTypes.setter
    @property
    def __init__(self):
        for s in symbols:
            self.Data.Add(foot)
        Symbols = []
            curveA = gd_a.Curve
            curveB = gd_b.Curve
            symA = gd_a.Name
            symB = gd_b.Name
                continue
                    continue
        try:
                vm.AddType(foot)
        except ValueError:
        selected_foot = [vm.SelectedType for vm in self.Data if isinstance(vm.SelectedType, FootingType)]
        if selected_foot:
        self.Close()
        self.Close()
def main(doc=None):
    main()```
Thanks.
self._selected_type must be same type of self._types ( ObservableCollection[FootingType] ), so at initialization self._selected_type can’t be a string
a workaround is to create a dummy object
code IronPython3 for Dynamo tested on Revit 2025
there’s probably still room for improvement
import sys
import System
from System.Collections.Generic import List, KeyValuePair
#import Revit API
clr.AddReference('RevitAPI')
clr.AddReference("System.Core")
clr.ImportExtensions(System.Linq)
clr.AddReference("IronPython.Wpf")
clr.AddReference('System.Core')
clr.AddReference('System.Xml')
clr.AddReference('PresentationCore')
clr.AddReference('PresentationFramework')
#clr.AddReferenceByPartialName("WindowsBase")
from System.IO import StringReader
from System.Windows.Markup import XamlReader, XamlWriter
from System.Windows import Window, Application
from System.ComponentModel import PropertyChangedEventArgs
#from System.Windows.Controls import CheckBox, TextBlock, TextBox, ListBoxItem
import wpf
import itertools
import traceback
class FootingType(System.Object):
        self.d1 = d1
        self.d2 = d2
        self.d3 = d3
        if d1 < d2:
    @property
    def H(self):
        return self._dim[0]
    @property
    def W(self):
        return self._dim[1]
    @property
    def T(self):
        return self._dim[2]
    @property
    def Name(self):
        if 0 == self.W == self.H == self.T:
            return "??"
    def __hash__(self):
    def __init__(self):
        self.propertyChangedHandlers = []
    # define a method to raise the PropertyChanged event
    def RaisePropertyChanged(self, propertyName):
        # create a PropertyChangedEventArgs object with the name of the changed property
        args = PropertyChangedEventArgs(propertyName)
        for handler in self.propertyChangedHandlers:
            # invoke each of the registered property changed handlers with the ViewModelBase instance and the event arguments
            handler(self, args)
    # define a method to add a property changed handler
        self.propertyChangedHandlers.append(handler)
    # define a method to remove a property changed handler
        self.propertyChangedHandlers.remove(handler)
        self._types = ObservableCollection[FootingType]()
        self._types.Add(FootingType(0, 0, 0)) # create dummy object
        self._selected_type = self._types[0] # assign the dummy object at initialisation
    @property
    def Position(self):
    @Position.setter
        self.RaisePropertyChanged('Position')
    @property
    def LstTypes(self):
        return self._types
    @LstTypes.setter
        self.RaisePropertyChanged('LstTypes')
    @property
        self.RaisePropertyChanged('SelectedType')
    xaml_str = '''
    <Window
        Title="Footings"
        <Grid Margin="10">
            <DataGrid x:Name="Symbols" Grid.Row="1" Grid.RowSpan="2" AutoGenerateColumns="False" ItemsSource="{Binding}"
                <DataGrid.Columns>
                            <DataTemplate>
                                </ComboBox>
                            </DataTemplate>
                </DataGrid.Columns>
            </DataGrid >
                <DockPanel>
                </DockPanel>
                <DockPanel>
                </DockPanel>
                <DockPanel>
                </DockPanel>
            </StackPanel>
            </StackPanel>
                <DockPanel>
                </DockPanel>
            </StackPanel>
            </StackPanel>
        </Grid>
    </Window>
    def __init__(self):
        wpf.LoadComponent(self, StringReader(MyWindow.xaml_str))
        self.xData = ObservableCollection[Footings_VM]()
        print(symbols)
        for s in symbols:
            self.xData.Add(foot)
        #self.Symbols.ItemsSource = self.Data
        self.DataContext = self.xData
        Symbols = []
            curveA = gd_a.Curve
            curveB = gd_b.Curve
            symA = gd_a.Name
            symB = gd_b.Name
                continue
                    continue
        try:
            for vm in self.xData:
                vm.AddType(foot)
        except Exception as ex:
            print(traceback.format_exc())
        selected_foot = [[vm.Position, vm.SelectedType.Name] for vm in self.xData if vm.SelectedType.Name != "??"]
        if selected_foot:
            print(f"Selected Footings: {selected_foot}")
        self.Close()
        self.Close()
@c.poupin
Sorry for the late feedback.
As usual, you have the magic trick that reveals the issue! If I had spent hours on this, I wouldn’t have had the intuition to use a dummy object.
The issue is now resolved by implementing a dummy object, just as you suggested.
Now, I’m wondering if I can use WPF’s RelayCommand to handle the Ajouter, Supprimer, and Supprimer tous button actions to improve the code. What do you think?
I would only implement the clear method, avoiding deleting the dummy object
you’ll have to reset the comboboxes to their default values
Note
It might be a good exercise to port this code to PythonNet3
@c.poupin
After a few days’ break, I was finally able to implement the del_Click event, which allows me to delete the selected FootingType instance from the combobox dropdown list. However, for now, it’s still difficult for me to implement delAll_Click, which would allow deleting all FootingType instances.
here the final code:
Note: It is necessary to add the path for the lib subfolder within the attached Footings folder for the code to work as expected.
Footings.7z (1.5 KB)
Footings
import sys
sys.path.append(r"C:\Users\nono\OneDrive\Desktop\Footings\lib")
import System
import math
# Import Revit API
clr.AddReference('System.Windows.Forms')  # For MessageBox
from System.Windows.Forms import MessageBox
import wpf
import itertools
import traceback
from _mySymbols import FootingType
from _myMaterials import ConcreteMaterial, get_or_create_concrete_material
    def __init__(self):
            handler(self, args)
    @property
    def Position(self):
    @Position.setter
    @property
    def LstTypes(self):
        return self._types
    @LstTypes.setter
    @property
def _grids_symbols():
    symbols = []
        symA = gd_a.Name
        symB = gd_b.Name
        if gd_a.Curve.Intersect(gd_b.Curve) == SetComparisonResult.Overlap:
                symbols.append(symbol)
    return sorted(symbols)
    xaml_str = '''
    <Window
        Title="Footings"
        <Grid Margin="10">
                <DataGrid.Columns>
                            <DataTemplate>
                                          SelectionChanged="Types_SelectionChanged"
                                </ComboBox>
                            </DataTemplate>
                </DataGrid.Columns>
            </DataGrid >
                <DockPanel>
                </DockPanel>
                <DockPanel>
                </DockPanel>
                <DockPanel>
                </DockPanel>
            </StackPanel>
                <Button Content="Supprimer" Width="85" Click="del_Click" VerticalAlignment="Top" Margin="0,20,0,10"/>
            </StackPanel>
                <DockPanel>
                </DockPanel>
            </StackPanel>
            </StackPanel>
        </Grid>
    </Window>
    def __init__(self):
        self.Data = {}
        self.DataTypes = ObservableCollection[Footings_VM]()
        self.symbols = _grids_symbols()
        for s in self.symbols:
            self.DataTypes.Add(foot)
        self.DataContext = self.DataTypes
        self.selected_position = None
    def Types_SelectionChanged(self, sender, e):
        if sender.SelectedItem is not None:
            self.selected_position = sender.SelectedItem
        try:
            for vm in self.DataTypes:
                vm.AddType(foot)
        except ValueError:
            MessageBox.Show("Please enter valid numeric values for dimensions.", "Error")
    def del_Click(self, sender, e):
        if self.selected_position is not None:
            index_to_remove = None
            for item in self.DataTypes:
                if self.selected_position in item.LstTypes:
                    index_to_remove = item.LstTypes.IndexOf(self.selected_position)
                    break
            if index_to_remove is not None:
                    if index_to_remove < len(item.LstTypes):
                        item.LstTypes.RemoveAt(index_to_remove)
                        if len(item.LstTypes) == 0:
                            default_type = FootingType(0, 0, 0)
                            item.LstTypes.Add(default_type)
                            item.SelectedType = default_type
                        elif item.SelectedType is None or item.SelectedType == self.selected_position:
                            item.SelectedType = item.LstTypes[0]
    def _collect_input_data(self):
            if len(item.LstTypes) < 2:
                MessageBox.Show("Please add at least one footing type", "Error")
                return False
            elif item.SelectedType is None or item.SelectedType.H == 0:
                MessageBox.Show("Please select a footing type for each Position", "Error")
                return False
        if not self.contrainte_value.Text:
            MessageBox.Show("Please enter a valid value for : contrainte", "Error")
            return False
        try:
            self.Data["foot"] = [vm.SelectedType for vm in self.DataTypes if vm.SelectedType.Name != "??"]
            self.Data["contrainte"] = self.contrainte_value.Text
            return True
        except ValueError:
            MessageBox.Show("Invalid input detected. Please ensure all inputs are numeric where required.", "Error")
            return False
        if not self._collect_input_data():
            return
        if not self.Data:
            return
        self.Data["lvl"] = get_foundation_level()
        self.Close()
        self.Close()
def get_foundation_level():
    levels = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Levels) \
    return min(levels, key=lambda l: l.Elevation)
def get_grid_intersection_points(grids):
    lstPts = []
        curveA = gd_a.Curve
        curveB = gd_b.Curve
            continue
            interResult = results.Value
            lstPts.append(interResult[0].XYZPoint)
            lstPts.sort(key=lambda p: (p.Y, p.X))
    return lstPts
def CreateFootingTypes(LstTypes, doc):
    all = list(LstTypes)
    created_types = []
    symbols = FilteredElementCollector(doc) \
            .WhereElementIsElementType() \
            .OfCategory(BuiltInCategory.OST_StructuralFoundation) \
            .ToElements()
    footing_names = {"Base rectangulaire", "M_Base-Rectangulaire"}
    existing_types_dict = {Element.Name.GetValue(fs): fs for fs in symbols if fs.FamilyName in footing_names}
    created_types_dict = {}
    with Transaction(doc, "Create Footing Types") as t:
        t.Start()
        for ft in all:
            if ft.Name in existing_types_dict:
                created_types.append(existing_types_dict[ft.Name])
            elif ft.Name in created_types_dict:
                created_types.append(created_types_dict[ft.Name])
                first_type = next(iter(existing_types_dict.values()), None)
                if not first_type:
                    MessageBox.Show("No existing footing family found.", "Error")
                    return None
                new_type = first_type.Duplicate(ft.Name)
                new_type.LookupParameter("Largeur").Set(ft.H / 30.48)
                new_type.LookupParameter("Longueur").Set(ft.W / 30.48)
                new_type.LookupParameter("Epaisseur de fondation").Set(ft.T / 30.48)
                created_types.append(new_type)
                created_types_dict[ft.Name] = new_type
        t.Commit()
    return created_types
def Create_footings(points, family_symbol, level, material_id, doc):
    with Transaction(doc, "Create Footings") as t:
        t.Start()
        for p, s in zip(points, family_symbol):
            foot = doc.Create.NewFamilyInstance(p, s, level, StructuralType.Footing)
            material_param = foot.get_Parameter(BuiltInParameter.STRUCTURAL_MATERIAL_PARAM)
            if material_param:
                material_param.Set(material_id)
        t.Commit()
# Main execution
Data = foundation.Data
family_symbol = CreateFootingTypes(Data["foot"], doc)
concrete_material = ConcreteMaterial(Data["contrainte"])
material_id = get_or_create_concrete_material(concrete_material, doc)
if family_symbol:
    points = get_grid_intersection_points(grids)
    Create_footings(points, family_symbol, Data["lvl"], material_id, doc)
OUT = 0
Thanks.
