Is it possible to Set Element Position Rotate Mirror? It is the reverse of Get Element Position Rotate Mirror note.
The bottom parameters has to override the top parameters.
I think you would just have to rotate and mirror separately. Do you run into any issues if you try that?
I just fix it with a workaround.
Filter the mirror and degree parameters and look what the result is for the angle. Then code Python to look for the configuration of the results and return an angle.
