Hello Guys,
I have created dynamo script to ‘Turn On/Off’ crop region visibility for sections.
But it is giving ‘warning: Internal error, please report: Dereferencing a non-pointer’ at node ‘Element.SetParameterByName’.
Could you please advise me?
FYI: I am using Revit 2015 & Dynamo 1.2 version.
Thank you for your help.
Set Crop Region Visible or Not Visible For Section.dyn (14.1 KB)
Hello Lucifer,
Thank you for your advice.
I tried your solution but no luck.
lucifer
4
should be feeding element not value
Hello Lucifer,
Thank you for quick response.
I tried but showing same warning.
Hello Lucifer,
My Apologies.
Initially i misunderstood, Again i tried your solution & it is working properly.
Thank you again for your help.
See below image without warning.
Set Crop Region Visible or Not Visible For Section_Warning Resolved.dyn (9.1 KB)
