Set column type instance for each level using wpf
@c.poupin
I’m still struggling and haven’t found a better approach than the one I previously tried to delete a specific type across all LstTypes and refresh the view to display the default_type (ColumnType(0, 0), which represents a dummy object) for symbols whose instances were deleted?
Please help me
Thanks.
Perhaps consider a contextual menu in the datagrid (right-click a row to delete the selected type), I’ll see if I can find the time, as this is not a task that can be done in a few minutes (even with the help of an AI).
@c.poupin
I was able to solve this issue with ChatGPT’s help. I couldn’t directly access the DataGrid row representing the SelectedType to delete, but ChatGPT guided me to use VisualTreeHelper to locate and access it through the visual tree.
Here my final code:
    def btnDelete_Click(self, sender, e):
        try:
            current_level = self.tabLevels.SelectedItem
            if current_level is None:
                return
            # Get the type to delete from the selected symbol in current level
            selected_type = None
            for symbol in current_level.Symbols:
                if symbol.SelectedType is not None and symbol.SelectedType != current_level.default_type:
                    selected_type = symbol.SelectedType
                    break
            if selected_type is None:
                forms.alert("Please select a symbol with a valid type to delete.")
                return
            for level_vm in self.DataLevels:
                for symbol in level_vm.Symbols:
                    if symbol.SelectedType == selected_type:
                        symbol.SelectedType = level_vm.default_type
                # Remove the type from this level's type list
                to_remove = [t for t in level_vm.LstTypes if t == selected_type and t != level_vm.default_type]
                for t in to_remove:
                    level_vm.LstTypes.Remove(t)
                if to_remove:
                    level_vm.notify_property_changed("LstTypes")
        except Exception as ex:
            forms.alert("Error deleting type: {}".format(ex))
Thanks.
