Searching a package
Can anybody tell which package String.RemoveAfterCharacters , String.RemoveCharacterAtIndex belong to?
String.RemoveAfterCharacters=Rhythm
The second i don’t know…but maybe i have my package version is to old
The zebra package has a node like that:https://dynamonodes.com/category/zebra/
Thanks for your reply.
There is one such node in Zebra package but even after I install it, the node shows ā€œUnresolvedā€
Yeah, it used to be. Until I was needing to remove all DYFs to maintain compatibility resulting in the removal of that node and others.
That being said, this python script will remove all characters after a given character if they are present :
Remove After Given Character
(paste the following into a python node)
# allows us to convert the input to a list to iterate over
def tolist(obj1):
	if hasattr(obj1,'__iter__') : return obj1
	else : return [obj1]
# inputs
strings = tolist(IN[0])
separator = IN[1]
# to return the new stuff
newStrings = []
# iterate through the strings
for string in strings:
	newStrings.append(string.split(separator,1)[0])
OUT = newStrings
And this script will return the character at the given index if there is a character there. If not, it returns null.
Character at Index
def tolist(obj1):
# inputs
index = IN[1]
character = []
	try:
		character.append(string[index])
	except:
		character.append(None)
OUT = character
Thanks a lot :slightly_smiling_face:
Of course! Hope that helps out. I updated the post to have CharacterAtIndex as well. :wink:
the CharacterAtIndex is working fine but Remove After Given Character shows this error message once Run :
Warning: IronPythonEvaluator.EvaluateIronPythonScript operation failed. **
** File ā€œā€, line 17, in
AttributeError: ā€˜list’ object has no attribute 'split’
Capture3
What does your input look like? Is it a list of lists? Because you might need to flatten it first.
This node saved my day !!! impossible to range my view and with that is cool … and my first test to use a code python and it’s run , happy, thanks john pierson !!!
