Script 2nd run altering results of the 1st run
Try upgrading to the latest Dynamo build 2.0.2 and see if that fixes it.
Roger that!
It solved the speed error! thanks for that. I am getting a new error now.
Warning: Sheet.ByNameNumberTitleBlockAndViews operation failed.
View 0 could not be packed on the Sheet. The sheet is 1.41666666666666 x 0.91666666666667 and the view to be added is 0.407291666666668 x 0.983473154687024.
Did you experienced that?
Nope - maybe the view offset related?
No I think the problem is my python node. Is not feeding the vectors in the correct order as the views are requesting it. Mind sharing yours?
mine is:
import RevitServices from RevitServices.Persistence
import DocumentManager from RevitServices.Transactions
import TransactionManager   from System.Collections.Generic import *
# Import RevitAPI clr.AddReference("RevitAPI")
app = uiapp.Application
#The inputs to this node will be stored as a list in the IN variable.
pcE = IN[0]
PCtransforms = []
PClocations = []
r=[]
if isinstance(pcE,(list,)):
  for i in pcE:
    e = UnwrapElement(i)
    tbX = e.GetTotalTransform().BasisX
    vecX = Vector.ByCoordinates(tbX.X, tbX.Y, tbX.Z)
    tbY = e.GetTotalTransform().BasisY
    vecY = Vector.ByCoordinates(tbY.X, tbY.Y, tbY.Z)
    tbZ = e.GetTotalTransform().BasisZ
    vecZ = Vector.ByCoordinates(tbZ.X, tbZ.Y, tbZ.Z)
    r.append([vecX, vecY, vecZ])
  e = UnwrapElement(pcE)
#Assign your output to the OUT variable
OUT = r
Them I grab each list of vectors with:
a@L2<0>;
a@L2<1>;
a@L2<1>;
respectively on DS code nodes. Where a is the list from the python node.
there is an alternative
Hi Marcel, I was just thinking of that! Thanks for the tip! I will be sure to give it a try!
hi @lucaspfmoreira
try this node:
Hi, I will! Thanks, I appreciate the help!
