hi everyone,
I’m trying to do this work, but I got stuck: I would like to replace a filer value of a schedule with a new value. I found a solution that allow me to create a new filter, but I can’t find the solution to replace the filter with the new one. I tried a lot of time but I didn’t find anything. Can someone help to to solve this problem?
Thanks!
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
refschedule = UnwrapElement(IN[0])
tgtschedules = UnwrapElement(IN[1])
tgtstrings = IN[2]
refdefinition = refschedule.Definition
reffilter = refdefinition.GetFilter(0)
tgtdefinitions = []
tgtfilters = []
a = refdefinition.GetFieldId(0)
b = reffilter.FilterType
for tgtschedule in tgtschedules:
tgtdefinition = tgtschedule.Definition
tgtdefinitions.append(tgtdefinition)
for tgtstring in tgtstrings:
tgtfilter = ScheduleFilter(a, b, tgtstring)
tgtfilters.append(tgtfilter)
for tgtdefinition, tgtfilter in zip(tgtdefinitions, tgtfilters):
tgtdefinition.InsertFilter(tgtfilter,0)
OUT = len(tgtdefinitions);
I have not tested it, but I think the ViewSchedule.Definition.SetFilter(index, ScheduleFilter) might be what you need, as the description states it’s function is “Replaces a Filter”.
Try it out and post back.
http://www.revitapidocs.com/2015/4432b9a9-a1ed-17c1-90a4-9c87d1a4fdcc.htm
Hi Gui_Talarico,
thanks for your reply
i used the method that you show me and now it works! Thanks!
here is the code:
# Import RevitAPI
tgtstrings = IN[2]
tgtdefinitions = []
tgtfilters = []
tgtdefinition.SetFilter(0,tgtfilter)
can I ask you another help? now I can feed the python node just with one “View”. can you help me to edit the code in order to feed the python node with more than one “View”? thanks a lot!
Try this
I think it need to distribute into each list
mmm no… it doesn’t work… I think that is a problem of the python code, not of dynamo
Hi @ste_camp , can you please start a new thread for that question? the original issue of this thread has been solved. Thanks!
