Hi Team,
At the bottom revit tab, u can find 1/8" "
=1’0" …
may i know what node is available to change scale ?..
Hi Team,
=1’0" …
If you search for “scale” in the library you should find exactly what you need. There are two out of the box nodes, View.Scale and View.SetScale, to get and set the scale of a view respectively. Keep in mind the value used here is actually a scale factor.
thankyou its working for me
