This
is on my to-do list.
And i already figured i probably have to partner with our ICT.
This
@jacob.small
But on my ‘control’ environment the Packages that are used are in the roaming folder.
So i am unsure how to go about this.
Hypothetically.
I i would install Packages from within Dynamo on a network folder which i have read and write
rights for and users only read rights, but use that path to get their Packages from would that
solves the blocked file issue?
EDIT
Nevermind. It seems i can’t change the download to folder.
I really need ICT
My steps would be:
%appdata%Dynamo\Dynamo Revit\3.4.After putting this on the side for a bit i decided to have a look into this again and i think i found the culprit. The network folder. After i zipped the Packages and i put them in a folder with less ‘restrictions’ everything seemed to work
(using your steps 8, 11 and 12 @jacob.small) ![]()
