Hi everyone,
I’m not a programmer or anything so I don’t know much but I’m trying to figure out a Dynamo script that could help me copy a Wall Keynote parameter to a shared custom made part parameter AND a way to copy the wall mark to the part mark.
How can I do this?
Hi Semi,
It is great to see you in the community! Hopefully, you will find your answers here.
Basically you will need Element.GetParameterByName and Element.SetParameterByName nodes. If you need to retrieve a type parameter value, you will also need Element.ElementType node to reach the correct element and parameters.
Here is a basic example which is similar to what fgn.87 shared:
Please, let me know if you need further help!
Thx, it works! Just not fond of packages, because every Revit version update this could result in a not working script
