Revit not regenerating view after creating parts
Hello, I am experimenting with diving walls into parts using the amazing script create by Einar on this post:
The problem is, after a successful run of the scrip, Revit does not regenerate its view, so I can’t see or interact with the created parts using Revit.
But if I manually create parts from another element, it immediately updates the previous elements and then I can see the parts.
Is there a way to “refresh” the view and have the expected result in the script?
I am using Revit 2019.2 Thank a lot for the help!
Hi @lucaspfmoreira
Add boolean input in python to refresh view.
Cheers!
Thanks, for your Help, but I have tried that already!
Looks like I just found the method on the Revit API.
it is the PartsVisibility option.
the new code is:
clr.AddReference('RevitAPI')
clr.AddReference('System')
wall = UnwrapElement(IN[0])
divisionLines = [l.ToRevitType(True) for l in IN[1]]
sketchPlane = UnwrapElement(IN[2])
#Create a list for the wall and the divisionLines
wallList = List[ElementId]()
wallList.Add(wall.Id)
intersectionElementsIds = List[ElementId]()
curveArray = List[Curve](divisionLines)
#All actions that make changes to the Revit database needs to be inside a Transaction
if PartUtils.AreElementsValidForCreateParts(doc, wallList):
	createParts = PartUtils.CreateParts(doc, wallList)
	doc.Regenerate()
parts = PartUtils.GetAssociatedParts(doc, wall.Id, True, True)
partDivide = PartUtils.DivideParts(doc, parts, intersectionElementsIds, curveArray, sketchPlane.Id)
doc.ActiveView.PartsVisibility  = PartsVisibility.ShowPartsOnly;
uidoc.RefreshActiveView()
OUT = partDivide
That does the trick.
