Revit Link Instance from Revit link Document
Is it possible to retrieve Revit Link Instance from Revit link Document.I know that reverse is possible using RevitLinkInsance.GetLinkDocument.
With the infinite number of documents available, it’s pretty much a certainty that any given document will not have a link instance in a given file. What input would you provide to ensure some degree of overlap without first querying the content in the document?
It may be that you want to pull the transmission data from a given .rvt, and get all the paths from there. This will be faster then querying the links as you can do this for any .RVT without opening the file (TransmissionData.ReadTransmissionData method). From there you can GetAllExternalFileReferenceIds, use that to GetLastSavedReferenceData, and use the ExternalReference object which that returns to GetAbsolutePath.
an idea using the hashcode document
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import net library
from System import Array
from System.Collections.Generic import List, IList, Dictionary
clr.AddReference("System.Core")
clr.ImportExtensions(System.Linq)
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
allsDocs = DocumentManager.Instance.CurrentUIApplication.Application.Documents
linkdocs = [x for x in allsDocs if x.IsLinked ]
linkdocsTitle = [d.Title for d in linkdocs]
def get_RvtLinkInstance(check_doc):
	linkInstance = FilteredElementCollector(doc).OfClass(DB.RevitLinkInstance) \
												.Where(lambda x : x.GetLinkDocument() is not None \
												and x.GetLinkDocument().GetHashCode() == check_doc.GetHashCode()).First()
	return linkInstance
OUT = linkdocsTitle, [get_RvtLinkInstance(i)for i in linkdocs]
