Hello all,
From civil 3D I exported a 3D Solid to a .json file. Now with Dynamo I want to create a revit geometry from the json file.
Do you have a workaround to propose to me?
Thank you in advance!!
Hello all,
How? What is the structure?
I have used similar workflows at scale so certainly doable, but the specifics matter.
You can do it, but you have to decide on the best structure to use for the data.
This all depends on the final product that you want to do, this includes the families/categories used in revit as well as what data you are taking from civil 3d as well.
Ok… and how are we supposed to know what that warning is?
And how are you writing out the values?
The community can’t do all of the work for you while guessing at what your issue is.
Sorry I didn’t notice that the warning message wasn’t visible.
The message is : ’ Geometry.FrimSolidDef operation failed. Failed to create geometry from solid def. JSON: IG_SURFACE_ILLEGAL --illegal surface definition
Looks like a geometry scaling issue to me. Try the export on medium in Civil 3D.
If that fails see if you can use the Data.Remember node to serialize the surface in Civil 3D, and open the same graph in Revit.
Couple of things to be aware of and check:
